March 24, 2011, 09:12 |
introduce air to water flow
masoud
hi
I want to know how to introduce air with constant velocity into water flow in one fluid and free surface? |
March 24, 2011, 09:58 |
veysel
hi
i wanna make a nozzle analysis. water goes to air. i dont know how to do. Can anyone help me to_? |
April 4, 2011, 04:51 |
Mohammad Sarfaraz
Rep Power: 16 |
April 4, 2011, 04:52 |
Mohammad Sarfaraz
Rep Power: 16 |
April 5, 2011, 00:19 |
cfd analysis of heat transfer in a tube with inserts
praveen kumar
in my case...in fluent after some iterations it is giving floating point error...
what is the floating point error?why it is coming? |
October 2, 2011, 15:09 |
#6 | |
behnam
Rep Power: 15 |
i see this error when i used some zero value for initializing the model parameter, change this value and if their real value is zero use small value in initializing menu. |
February 19, 2012, 05:31 |
Rep Power: 14 |
hi
do you know in flow 3d how we can use air entrainment in specified sections?in spillways I mean.and also about parameters.specially entrainment rate ceofiecient...I have no idea about it. thanks |
September 8, 2016, 03:02 |
Masoud Ravan
Rep Power: 10 |
Hi everyone
I want to inject air (with known rate) from bottom of the channel to water flow? I dont know if Flow3D could simulate this...and also i think airentrainment submodel Pulls air into the water flow due to turbulence Please help me.. Tanks |
September 13, 2016, 04:19 |
#9 | |
Yu Zhou
Rep Power: 12 |
you can try "mass momentum source" to inject air to water |
September 13, 2016, 09:06 |
#10 |
Masoud Ravan
Rep Power: 10 |
September 13, 2016, 09:15 |
#11 | |
Masoud Ravan
Rep Power: 10 |
This article is like your problem except that they used Ansys FLUENT 15 for their modeling. I wish it could help you. All the best, Masoud Ravan http://www.tandfonline.com/doi/abs/1...nalCode=tjaw20 |
Ansys Fluent UDF - for Data Center Air flow management | kedarjan | Fluent UDF and Scheme Programming | 13 | November 13, 2013 04:20 |
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 17:16 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
HELP!!! Indoor air flow pattern | Peter Zhang | Main CFD Forum | 4 | November 3, 1999 02:49 |
