Home > Forums > Software User Forums > FLOW-3D
Installation problem for 64-bits system
Old   March 24, 2011, 04:38
Post Installation problem for 64-bits system
Chande
Chande is on a distinguished road
Hi!
Flow3d could run well when my computer system was 32-bits. However, after i changed the system to 64-bits, it said "abnormal exit from preprocessor" when i try to preprocess a simulation.
Is it the problem of the computer system, what should i do now?
By the way, i have installed the "visual studio 2010"&"Intel Fortran 11", which are the requirements for 64-bits system.
Chande is offline   Reply With Quote
Old   March 27, 2011, 18:59
ignatz is on a distinguished road
Chande,
Who is your distributor, and have you contacted them for help? A solution is out there...call your distributor for help. If they don't know, Flow Science will help them.
BTW, you do not need either the compiler or Vis Studio for straight-forward running of FLOW-3D...only if you want to customize any of the subroutines.
ignatz is offline   Reply With Quote
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 19:13
OF Installation Problem - Gcc Error Daniel Pilatti OpenFOAM Installation 11 April 19, 2009 23:07
Paraview installation problem please help mcjicpm2 OpenFOAM Installation 0 March 9, 2009 07:55
problem in installation of Fedora code peter Main CFD Forum 1 August 22, 2006 10:03
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
