January 23, 2011, 07:05 |
Turbulence model
Atiieh Rostami
Rep Power: 17 |
Hi Dears
I want to simulate the undular hydraulic jump (hydraulic jump with stationary wave).In first step, I did the model with laminar flow. In next step I want to study the turbulence model in this area. When I active k-e or RNG model, the simulation is terminated after a minute. What should I do for the simulation? Regards |
January 24, 2011, 01:27 |
#2 | |
Daniel
Rep Power: 16 |
May be you are using an implicit model for viscosity. I mean, RNG and k-eps are turbulence models based on a dissipation and a transport equation. In this kind of models (which involve a transport equation), viscous diffusion terms are always aproximated explicitly. Hope it helps |
January 26, 2011, 00:42 |
#3 | |
Atiieh Rostami
Rep Power: 17 |
Thank you for reply. I used explicit model for viscousity when I do with K-e or RNG but I got same result . I received this message from Flow3D: ============= mentor tip =============== persistent f-packing location at t= 0.52021E+01 x= 0.99991E+01, y= 0.00000E+00, z=-0.33636E-01 i=5495, j= 2, k= 5 f= 0.96045E+00 recommend reducing cfpk by factor of 10 ======================================== I change cfpk to 10 or 20 but the procedure did not change. Regards Ati |
January 26, 2011, 02:36 |
Daniel
Rep Power: 16 |
try with some Vof Lagrangian model and/or no F-Packing at the beginning of the simulation at least
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 17:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 17:15 |
