How can I maintain a constant volume during the simulation period? |
January 20, 2011, 08:45 |
bejewel
Rep Power: 15 |
Boundary Conditions:
Xmin:wave Xmax: outflow front ,back & bottom:wall top: outflow How can I maintain a constant volume during the simulation period? |
January 20, 2011, 13:26 |
michael barkhudarov
Rep Power: 18 |
Not easy. The degree of conservation depends on mesh resolution, VOF scheme used and velocity advection. Split Lagrangian VOF method may work better.
January 25, 2011, 12:40 |
Jeff Burnham
Rep Power: 17 |
To add to MuxaB's response, you can also make the domain long enough in the direction of wave propagation that the transit time required for three waves to reach the downstream outflow boundary is sufficient to find the results you need. The wave-propagation mass conservation issue at the outflow boundary usually takes three full wave fronts to start to significantly appear.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
constant volume pump bc udf | Adammada | FLUENT | 0 | July 29, 2009 07:58 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 03:34 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 24, 2001 00:16 |
