January 2, 2011, 08:01 |
I want to simulate a Wave in the flume
mahdi
Rep Power: 15 |
I want to simulate a Wave in the flume..
how should I define boundary conditions ? I mean in which direction should I define Flow? |
January 17, 2011, 02:39 |
michael barkhudarov
Rep Power: 18 |
wave are always defined at the x or y mesh boundaries, i.e., vertical boundaries. Designate a mesh boundary a wave boundary, set the initial fluid volume in the domain using fluid height, use the same height at the wave boundary, set the wave length and amplitude - and you are good to go.
January 17, 2011, 05:27 |
mahdi
Rep Power: 15 |
Tnx a lot for help..
but.. what do u mean by : " wave are always defined at the x or y mesh boundaries .. " you mean there is no mesh need for Z direction ? |
January 19, 2011, 01:45 |
michael barkhudarov
Rep Power: 18 |
No, mesh should be defined in all three directions. What I meant is that in FLOW-3D surface wave generators are implemented as mesh boundary conditions and can be applied at any of the four mesh boundaries, xmin, xmax, ymin or ymax.
January 19, 2011, 06:20 |
mahdi
Rep Power: 15 |
thank you for informations.
fortunately after all I simulated the wave but there is another problem I faced, is the water dept decrease gradually . I chose X min ( LW ) but really i don't know what should I choose for X max ? in case of " continuative " the water dept decreased gradually. in case of " Symmetry " water turn back after it reach to the end of mesh. can u help me with that ? i need no decrease in water dept and continuant wave for example like a seaside. |
January 19, 2011, 10:38 |
Stefano
Rep Power: 17 |
choose the "Outflow" b.c. with the option "Allow fluid to enter...".
January 20, 2011, 04:55 |
mahdi
Rep Power: 15 |
thank you Stefmascio...
but there is still dept decreasing.. |
January 22, 2011, 00:50 |
mahdi
Rep Power: 15 |
Dear Stefmascio...
When I did your suggestion for choosing the "Allow fluid to enter...” after running simulation the water dept start decreasing gradually and suddenly after 20 sec, new stream started coming into the flume with reverse direction, interfacing the waves and the incoming fluid cause an overtopping the water depth… so this suggestion might not be a proper solution.... do u have any other idea ? |
January 22, 2011, 21:43 |
#9 |
bejewel
Rep Power: 15 |
Model Setup\ Numerics\Wave boundary conditioon
then to choose: Eliminate net volume flux at wave boundary,or Include net volume flux at wave boundary. good luck! |
January 23, 2011, 03:08 |
#10 |
mahdi
Rep Power: 15 |
Dear Bejewel ...
there is no " wave boundary condition " in Numerics .... and really I could not fined any of your suggestions there.... thank you any way |
January 24, 2011, 05:58 |
#11 |
Armen A. Ghirghidov
Rep Power: 17 |
Dear mahdi,
Try to change mesh resolution. Regards. |
January 25, 2011, 11:04 |
#12 |
bejewel
Rep Power: 15 |
Flow-3D 9.4---> " wave boundary condition " in Numerics
Outlet boundary condition for wave flume with interFoam solver | Arnoldinho | OpenFOAM | 9 | July 10, 2018 06:15 |
How to simulate a sea wave striking a ship antenna | Freeman | FLUENT | 0 | February 25, 2009 15:17 |
to simulate shock wave propagation with turbulence | cfdgeek | Main CFD Forum | 1 | August 31, 2008 17:47 |
simulate propagating wave | Gian, S. | Main CFD Forum | 0 | October 27, 2006 04:11 |
how to simulate wave? | dingding | CFX | 3 | July 18, 2001 12:20 |
