Home > Forums > Software User Forums > FLOW-3D
Elastic stress and rapid shrinkage model
Old   December 16, 2010, 02:53
Default Elastic stress and rapid shrinkage model
zhou le
zhoule0130 is on a distinguished road
I want to know whether the elastic stress and rapid shrinkage model (in solidification) can work at the same time?
Thank you!
zhoule0130 is offline   Reply With Quote
Old   January 17, 2011, 02:43
michael barkhudarov
MuxaB is on a distinguished road
Thank you!
No, they can't.
MuxaB is offline   Reply With Quote
Old   January 17, 2011, 03:17
zhou le
Originally Posted by MuxaB View Post
No, they can't.
If I want to apply the elastic stress molde during the solidification, what should I do ? How do I set the simulation?
Thank you very much!
Old   January 19, 2011, 01:48
michael barkhudarov
Your best reference in the example problem for the thermal stress model provided as part of the installation. It is located in the folder Examples/thrmstrs. In that example, an aluminum part is cooling in air outside the die. It has all the setup elements, except it start at the part already solid. You just need to change the initial temperature to make it liquid.
