Home > Forums > Software User Forums > FLOW-3D
Multi meshing blocks
Old   October 19, 2010, 11:31
Exclamation Multi meshing blocks
Daniel
Davahue is on a distinguished road
Hi, I've been trying to use some blocks at the same simulation. First, I have fixed some points to enhance the blocks and I've restricted manually the ratio between both block's cells near the unity.
But when I simulate, it's like the flow stops at the boundary, like a wall!
I've been trying with outflow B.C. allowing inflow, and continuity B.C. but the problem persists...
What's Wrong? Could anybody help me please?
thanks in advice!
Davahue is offline   Reply With Quote
Old   October 20, 2010, 04:18
Default Multi meshing blocks
Renaud GORRIA
Renaud GORRIA is on a distinguished road
You should set Symetry BC between the different blocks of your simulation. It will works
(symetry means "by default" in this case, the solver reads it corretly as a condition between multi-blocks)
Renaud GORRIA is offline   Reply With Quote
Old   October 21, 2010, 08:52
Daniel
I've checked symmetry BC at the Boundary tabs for the block #2 (that is into the block #1), I run simulation and I still get the same problem, what happens? is this the BC you told me? or can I edit another kind of BC between blocks?
thanks in advice!
Old   October 22, 2010, 03:52
Renaud GORRIA
You must check all the six-BC of the block 2 as Symmetry BC.
And if the block 2 considers one side which is the same plane that a side of the block 2 (for example your block 2 is inclued in Blk1 but both start on X=0), so you have to check the same BC on the 2 sides (blk1 ande blk2). For my example Specified Presssure on X=0.
Is it your case? Is your blk2 totally inclued in blk1?
Old   October 23, 2010, 16:02
michael barkhudarov
MuxaB is on a distinguished road
One possible reason two adjacent mesh blocks not to be connected properly is a gap between them, so make sure that the coordinates of the mesh boundaries on both blocks are identical.
The definition of the inter-block block boundaries depends only on the relative position of the blocks, i.e., the coordinates of the boundaries. Once the pre-processor determines that the two mesh blocks are adjacent, it set the boundary type to inter-block irrespective of the user input.
The parts of an inter-block boundary that are NOT facing another block are always treated as a wall.
MuxaB is offline   Reply With Quote
Old   October 24, 2010, 10:25
Daniel
My block 2 is completly into de block 1, I've set 2 fixed points in each direction, and I've set simmetry boundary conditions in Boundaries... but it still don't run as I want.. it runs the boundaries as a wall.
When I start to simulate, I get that message:
open area mismatch at inter-block boundaries of all blocks as % of total open area at these mesh boundaries = 5.96348E-12
so I think, I've put correclty all.. but there should be a problem at the BC so I've copied here my text information:
&bcdata
wl=11, wr=8, wf=2, wbk=2,
flrbct(1,1)=16.,
&mesh
nxcelt=80, px(2)=-3., nycelt=40, nzcelt=10, pz(2)=1.0, px(1)=-10., py(1)=-4., py(2)=-2., pz(1)=0.0, px(3)=7., px(4)=20., py(3)=2., py(4)=4.,
&bcdata
iobctp(1)=1, iobctp(2)=1, iobctp(3)=1, iobctp(4)=1, iobctp(5)=1, iobctp(6)=1, ipbctp(1)=0,
&mesh
nxcelt=100,
px(1)=-3., px(2)=7., nycelt=100, py(1)=-2., py(2)=2., nzcelt=10, pz(1)=0.0, pz(2)=1.0,
Another appointment is that when I see the results, the solid that is into the block 2,
don't seem to have the resolution it must have, it has the definiton that the block 1 gives it...
I've also tried to put interblock BC manually and doesn't happen anything different!
Could help me please?
thanks in advice!
Old   October 26, 2010, 05:54
Renaud GORRIA
In your prepin I can see that the top and the bottom of the blk1 and blk2 are adjacent. I think it comes from this point... try to set up a blk2 strickly IN the blk1.
Old   October 29, 2010, 01:27
michael barkhudarov
Even with coincidental bottom and top boundaries in z-direction, it looks in order to me. The flow should proceed along the x-direction. Could you please attach an image of the solution you receive?
One other question. When you post-process do you have both blocks selected under Mesh Block button in Analyze tab or just block 1 (which would be the default in earlier versions of FLOW-3D).
Old   October 30, 2010, 17:03
Daniel
Now it runs ok, the problem was in the postprocess, I didn't konw that I had to check both meshes, I hadn't seen this tab in Analyze, now it's all OK. Thanks!!
I'm very gratefull with both of you, I hope it could help somebody else!
Old   November 1, 2010, 00:50
michael barkhudarov
You are very welcome, Davahue. Glad it worked.
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 10:04
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 20:13
[blockMesh] Problems meshing wedge type blocks Alan OpenFOAM Meshing & Mesh Conversion 0 July 27, 2009 21:05
How to creat Chimera structured multi blocks grid jeevan kumar CFX 1 April 22, 2008 01:45
