September 15, 2010, 05:14 |
oscillatory flow
jiko
Rep Power: 16 |
I am going to model a rigid body in oscillatory flow(say in x direction). Can someone hint about the inlet and outlet configurations. I mean what boundary conditions Flow3d offers for such simulations. Thanks in advance |
September 17, 2010, 02:32 |
michael barkhudarov
Rep Power: 18 |
You can define pressure at inlet and outlet or flow rate (or velocity) at the inlet and outflow or fixed pressure at the outlet. If the incoming flow oscillating, the inlet bc conditions can be defined as a tabular function of time, up to 500 points.
September 17, 2010, 09:42 |
jiko
Rep Power: 16 |
Thanks MuxaB, for oscillating inflow do i need to specify tubular velocity at the inlet only or at outlet as well. because once the direction of the flow changes the inlet will become outlet and the outlet should serve as inlet.
regards |
September 18, 2010, 01:36 |
michael barkhudarov
Rep Power: 18 |
I see. The simplest thing you can do is have pressure at one boundary and velocity at the other, with the latter tabulated to represent the oscillations. The pressure bc should be made of type static rather than the default stagnation.
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 14:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 07:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 09:42 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 09:47 |
