Home > Forums > Software User Forums > FLOW-3D
Fortran compiler for customization
Old   September 6, 2010, 05:54
Default Fortran compiler for customization
Johannes Köpf
jk75 is on a distinguished road
Hi All,
as I understand it, I need the Intel Fortran Compiler 9.1 for customization (instead of the current Version 11). When I buy the current Version, I get an link to download the older version also.
But is there a possibility to get a test- 9.1- version? We are not yet sure if we need customization, so we wanted to test it before we spend a significant amount of money in it.
Best regrads,
Johannes
jk75 is offline   Reply With Quote
Old   September 6, 2010, 08:41
Johannes Köpf
got it! all you have to do is to register at https://registrationcenter.intel.com.../register.aspx in addition to the registration for the download of the test- version V11. Once registered in the RC also, you get access to older versions.
Old   September 8, 2010, 05:54
Unhappy compilation error!
Johannes Köpf
It seems I'm missing something...
I'm working on Red Hat Enterprise Linux - 64 bit.
I've got the non- commercial version of the INTEL Fortran compiler Version 9.1.052, using the 64- bit version found under directory '/fce/..'.
Running make wih no changes made works fine, no compilation errors.
Now I tested the 'Counting Particle Concentration in Mesh Cells' Example from the manual and get the following error messages:
fortcom: Error: qsadd.F, line 153: Unbalanced parentheses
*.lt.1) goto 2000
fortcom: Error: qsadd.F, line 153: Syntax error, found '.LT.' when expecting one of: <END-OF-STATEMENT> ;
*.lt.1) goto 2000
fortcom: Error: qsadd.F, line 18: This module file was generated for a different platform or by an incompatible compiler or compiler release. It cannot be read. [MBLOCK_MODULE]
use mblock_module
I guess the last one is the big one. It seems, the compiler is not able to use a single of these needed modules.
Has anybody an idea what I'm doing wrong?
Thanks in advance and best regards,
Johannes
Old   September 11, 2010, 14:50
michael barkhudarov
MuxaB is on a distinguished road
Make sure the lines start at column 7.
I don't understand the error message about mblock_module. If it compiles without changes it should compile with changes too.
MuxaB is offline   Reply With Quote
Old   September 15, 2010, 08:20
Johannes Köpf
Hello Michael,
yes, you were right. After I left the first 6 cols blank it compiled without problems. Fortran is still new to me...
Regards,
Johannes
Old   September 17, 2010, 02:33
michael barkhudarov
The Manual should be more clear with the coding examples. Glad you made it work.
Old   October 5, 2010, 11:30
Default compiler
jiko
jiko is on a distinguished road
Hi i did the registeration at the above mentioned link. now how do I find the intel 9.1 for windows64.
Thanks
jiko is offline   Reply With Quote
Old   October 6, 2010, 04:40
Johannes Köpf
Just go to the Registration Center and login with your ID. You will get to a page called 'My Intel Software Development Products' where all your licenced products (for example your intel compiler V11). On this page there is a link called 'search for older versions'. There you will find the V9.1.
I only registered for the Linux Version, so I'm not sure if this route works for Windows also.
Old   October 6, 2010, 08:04
jiko
Thanks .. I got it(the 9.1 compiler). but the visual studio is still 2008 . Could you hint that how to get microsoft visual studio 2005.
Old   October 14, 2010, 12:10
Default Book on Fortran
Johannes Köpf
Hi all,
is there a good book on FORTRAN (it's fortran90 one needs, isn't it?) you can recomend?
Reagrds,
Johannes
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 02:39
Fortran Compiler and example Young CFX 1 March 22, 2011 23:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
