Home > Forums > Software User Forums > FLOW-3D
projection method(3D)
Old   August 14, 2010, 22:37
Default projection method(3D)
Ehsan
ehsan_am86 is on a distinguished road
Hi
I want to simulation the flow in helical pipe.
I have one Continuity equation and three momentum equations in s=>(u),r=>(v),teta=>(w).
I used staggered mesh and descritized all of terms in central(finite difference).
I want to use projection method for solution these navier-stokes equations.
first problem:
What is stability condition for helical coordinates (three dimensional)in projection method?because I don’t know which number of interval in s,r,teta causes convergence!
second problem :
In descritized scheme we have i+2,i-2,j+2,j-2,k+2,k-2 indexes for u,v and w.
what do I have to do for the nodes of near the boundary? It means that two nodes produced out of domain but I don’t know value of them and they are unknowns.
Third problem:
We have to apply boundary conditions.in s and teta I have to apply periodic
Conditions.what are periodic boundary conditions for u,v and w in s and teta?
Is there any paper or books(references) for programming of projection method(three dimensional)?
Thanks for your guidance and aid
ehsan_am86 is offline   Reply With Quote
Old   August 28, 2010, 22:45
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by ehsan_am86 View Post
Hi
first problem:
second problem :
Third problem:
One possible way to resolve the second problem is to define so-called fictitious or ghost cells on each side of the mesh - two layers in your case. You will solve the equations in real cells, say up to index IMAX in the x-direction, and the ghost cells will store variable values in cells IMAX+1 and IMAX+2, so that you can reach out to use them without worrying about exceeding array dimensions.
The ghost cells may also help in imposing periodic boundary conditions.
MuxaB is offline   Reply With Quote
projection method for helical pipe(3D) ehsan_am86 Main CFD Forum 0 August 14, 2010 22:30
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
projection method sudhakar Main CFD Forum 4 December 8, 2007 02:25
free surface flow and projection methods sylvain Main CFD Forum 2 April 26, 2002 10:45
A Second-Order Projection Method for Incompressibl Ivan Main CFD Forum 5 April 29, 2001 08:27
