Home > Forums > Software User Forums > FLOW-3D
How to set up meshes of sparse and small holes?
Old   August 5, 2010, 23:57
Default How to set up meshes of sparse and small holes?
Ye Li
leeyee is on a distinguished road
Hi guys,
I have a problem when trying to model sparse holes in a cylinder. Our model is quite simple, it's just several holes in a solid cylinder. However, these holes are sparse and quite small compared to the radius of the cylinder. Specifically, it's just 3um radius for holes but the cylinder is 310um! So here comes the problem, I don't how to set up meshes to resolve such small holes but still remain consistency of cells so that Flow-3D can calculate. Otherwise I have to set up a dense mesh, but in that case Flow-3D is unacceptable slow and wasting most of the time calculate unneeded cells, because fluid only appears in holes, theoretically we don't need to calculate solid part. Can anyone help out?
Thanks sincerely.
leeyee is offline   Reply With Quote
Old   September 2, 2010, 23:50
michael barkhudarov
MuxaB is on a distinguished road
If there is no heat transfer, then cells inside blocked areas are automatically deactivated and removed both memory and calculation, leaving only the open cells active, so it would be ok to mesh the whole cylinder finely. Alternatively, you could use multiple mesh blocks concentrated around the holes, leaving the rest of the cylinder either unmeshed or mesh with a coarse mesh block.
MuxaB is offline   Reply With Quote
