June 17, 2010, 12:59 |
Non-condensable Gas
liang liam
Rep Power: 17 |
hello~every
I have a problem about.... does flow 3D can only have two fluids ? Can I use Non-condensable Gas(such as air) as the third fluid? from the User Manual I foundCondensation/Evaporation (Two Fluids with Non-condensable Gas)model,but I don't know how to use it. I have tried many times but failed... thanks! |
June 20, 2010, 20:06 |
michael barkhudarov
Rep Power: 18 |
You are right, there is a model for the liquid/gas system with the gas consisting of two components: vapor and a non-condensable gas.
There is an sample setup under the folder Examples called Steam-Air, i think, that has the typical input for a water/air/steam system. I think, it uses CGS units. |
June 23, 2010, 06:47 |
#3 | |
liang liam
Rep Power: 17 |
If I want using Non-condensable Gas(such as air) as the third fluid but don't mix with vapor ,from the initial/fluid region/fraction of non-condensable that I key the value as "1" ,does it means the Non-condensable Gas not mix with vapor?? thanks! |
June 28, 2010, 02:19 |
#4 | |
michael barkhudarov
Rep Power: 18 |
June 28, 2010, 13:06 |
liang liam
Rep Power: 17 |
michael thanks!!
ya! I just want the NC gas initial volume fraction that only defines the initial condition. I can use something to baffle NC & vapor at initial condition ,the NC & the vapor should not mix,i.e that can be third fluid to use? I just only want the heat transfer phenomenon by use third fluid(air). I know the gas in flow3D all follow the IDEAL GAS LAW (P=density*R*T) I define the NC fraction from the initial/fluid region/fraction of non-condensable that I key the value as "1" ,does anybody know another method to define the NC fraction? coz the fluid region/limiters look likes only the rectangular region to define. thanks !!!! Last edited by club68512; June 29, 2010 at 02:54. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Non condensable gas mas fraction for CAVITATION | Xa | Main CFD Forum | 0 | April 2, 2008 12:28 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
