June 9, 2010, 04:26 |
modeling the shot sleeve
Seunghyun Yoon
Rep Power: 16 |
Dear all,
I'm trying to model the shot sleeve for HPDC. I modeled the shot sleeve by making a cylinder and importing it as complement. then I made another cylinder as solid so I can model the plunger. Then I made the plunger as moving object and specified a z-axis velocity. I also set up the initial value so that half of the sleeve is filled with a380 with 0 velocity. Then I ran the simulation but the plunger seems not moving at all. Can anyone explain in detail how I should model the plunger? Thank you very much!! Seunghyun. |
June 9, 2010, 10:27 |
private
Rep Power: 17 |
What is HPDC? What is a "short sleeve"? What is "a380"?
Can you post a sketch and describe, in general terms, what it is you're trying to simulate? Perhaps then someone can make suggestions for you. |
June 10, 2010, 02:27 |
Seunghyun Yoon
Rep Power: 16 |
Problem solved. I modeled the plunger and sleeve and made the sleeve as a complement, and I think the plunger stuck in the outside of the sleeve that was modeled as a solid(cause I made the sleeve model as a complement).
Anyway, I made the sleeve a bit longer and made the plunger short and put it inside the sleeve void, and it works now. Thank you anyway. And HPDC( high pressure die casting) |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 08:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 10:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 20:08 |
