June 7, 2010, 17:35 |
how to plot the flux rate?
kent sun
Rep Power: 16 |
I am doing a simple model about the pipe flow.
I want to get the flux rate through a cross section. the baffles can help me, but i can't find how to display it? Could u help me? Thank u. |
June 7, 2010, 22:01 |
Rep Power: 17 |
you can go to Display-> View -> Baffle Option, then you can choose which baffle to show/hide or edit the color.
June 7, 2010, 23:28 |
Thank you
kent sun
Rep Power: 16 |
Thank you ck5258.
I want to get the curve of flux rate vs time. and it is a pity that i don't know how to do it. You tell me to click the baffle option, and there is no respond. it is crazy. i am fresh to the Flow3d. Thank u very much! |
June 8, 2010, 03:28 |
Rep Power: 17 |
Kent Sun you can go to Analyze -> Probe -> Data source -> General history -> look for flux surface plot. hope this help.
June 8, 2010, 14:07 |
kent sun
Rep Power: 16 |
Dear ck5258:
thank u again. I have try to find it on the general history, but i failed. there is no flux surface plot. so i think there is something wrong with my setting. i set the baffle definition z coordinate =10 limiters xl=0 xh=100 yl=0 yh=100 and the porosity is 1, define the baffles as a flux surface.all of these are set by the GUI. Is there anything else I didn't set? thank u for your patient. |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 04:27 |
how to plot heat flux along the wall ? | mahaputra | OpenFOAM Post-Processing | 3 | May 31, 2009 03:31 |
How to plot reaction rate? | kris | Siemens | 2 | August 27, 2004 06:58 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 09:45 |
How to Plot Mass Flow Rate w.r.t No. of Iterations | Julie | FLUENT | 2 | July 30, 2002 11:50 |
