April 18, 2010, 06:03 |
Friction coefficient
Belgio
Rep Power: 17 |
Help needed...
I am new to Flow3D, I'm trying to model the shock tube using the standard example model as a base. But it is impossible to change friction coefficient in turbulence settings (it is always -1.0). I've tried to change fluid viscousity and other parameters but that doesn't solve the problem. Friction is still -1.0. Thanks in advance! |
April 21, 2010, 19:10 |
michael barkhudarov
Rep Power: 18 |
You need to activate the viscous model in Physics > Viscosity and Turbulence. Make sure also that there is a non-zero viscosity coefficient in the fluid properties.
Using a positive friction coefficient means a partial slip at walls. Is it what you want to do for the gas? |
April 25, 2010, 13:34 |
Belgio
Rep Power: 17 |
Yes, I've tried what you said. Nothing helps. Miha! Pls. check your private inbox. Thx
April 25, 2010, 18:39 |
michael barkhudarov
Rep Power: 18 |
Gleb,
If you have viscous flow activated and the viscosity is positive, then there is friction at walls. The friction coefficient stays at -1, as it should for all fluid. The -1 value effectively means infinite no-slip BC. A 0 value would mean free slip, and a positive value means partial slip, which is suitable for solid-like materials. The fact that you do not see a noticeable effect on the shock is probably because the viscous boudnary layer is too thin to be resolved. |
March 8, 2011, 21:55 |
#5 | |
HLD
March 9, 2011, 03:30 |
Belgio
Rep Power: 17 |
No, I have not solved that.
March 12, 2011, 17:28 |
michael barkhudarov
Rep Power: 18 |
coefficient, friction |
Skin Friction Coefficient | FrenchyTim | FLUENT | 10 | January 15, 2018 10:41 |
Macro for skin friction and pressure coefficient | DoHander | Fluent UDF and Scheme Programming | 0 | January 9, 2010 10:18 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
coefficient of friction in Euler-Euler model | Wei | FLUENT | 0 | July 7, 2008 05:40 |
Friction coefficient | Dony | Main CFD Forum | 1 | March 9, 2006 07:32 |
