Home > Forums > Software User Forums > FLOW-3D
the big problem about flow3dMP
Old   April 16, 2010, 12:01
Default the big problem about flow3dMP
bojiezhang
bojiezhang is on a distinguished road
hello everyone:I am now using flow3d9.4MP,and I have a big problem.when i runpre_par,the result is like that
"processing geometry components
processing non-moving component 1 in mesh block 1
1
rank 0 in job 56 node1_35234 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
PREP3D complete",the runpre failed.
but when I use his example 'mblock',it runpre well and tells that
" processing geometry components
processing non-moving component 1 in mesh block 2
processing non-moving component 1 in mesh block 3
total and active cell counts: 25494 10666
I really do not understand it,please help me ,thank you very much!
bojiezhang is offline   Reply With Quote
Old   April 21, 2010, 20:12
michael barkhudarov
MuxaB is on a distinguished road
have you looked in the pre-processor output files, such as prpout or prperr, on each rank?
MuxaB is offline   Reply With Quote
Solver problem with a big amount of reactions Leonid CFX 2 April 9, 2007 11:38
I have a big problem of convergence, please help ! amel FLUENT 3 February 15, 2007 16:32
ICEM meshing problem Forrest CFX 4 May 25, 2005 19:37
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 01:15
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
