Home > Forums > Software User Forums > FLOW-3D
Shear force on rotating disk
Old   April 12, 2010, 09:06
Exclamation Shear force on rotating disk
Sam Martin
Squid is on a distinguished road
I'm new to floworks and I am modelling a Tesla turbine on floworks but cant get it to show the shear force that is acting on the disk.
I have a really simple model of an inlet that leads the fluid between 2 disks that I have spinning at a certain rpm and there is a hole in the centre of the disks for the water to flow out off. I can get do a surface plot or a 3D plot to show the pressure at different parts of the model but I am unable to make it show the shear force that is acting on disk.
Is there anyway to do this?
Any help would be much appreciated.
Squid is offline   Reply With Quote
Old   April 14, 2010, 10:30
michael barkhudarov
MuxaB is on a distinguished road
shear force can be viewed in the latest version 9.4 and for that you need to request this output in the Output tab. I think the option is called "Critical shear stress"
MuxaB is offline   Reply With Quote
Old   April 17, 2010, 17:33
ignatz is on a distinguished road
Squid,
You say you are "new to floworks". Do you mean to be in the FLOW-3D forum? If you're using Cosmos Floworks, the users here won't be able to help.
ignatz is offline   Reply With Quote
disk, floworks, shear, tesla
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 16:33
Rotating Disk MohsenZendehbad FLUENT 2 July 13, 2008 14:43
wall shear force with VOF Jürgen FLUENT 0 July 27, 2007 07:28
rotating disk David FLUENT 5 August 16, 2006 07:07
Numerical solution to the rotating disk problem? johny Main CFD Forum 7 September 5, 2005 06:53
