Home > Forums > Software User Forums > FLOW-3D
outflow boundary condition
Old   April 8, 2010, 01:15
Default outflow boundary condition
Yi-Lang Chen
Andy Chen is on a distinguished road
Dear experts:
When I set outflow boundary condition. There have an option that is
allow fluid to enter at outflow condition. What is mean about the
option(allow fluid to enter at outflow condition)?
Thanks your help!!
Andy Chen is offline   Reply With Quote
Old   April 8, 2010, 01:30
michael barkhudarov
MuxaB is on a distinguished road
Andy,
It is a special option when modeling linear or Stokes waves generated at the opposite mesh boundary. The fluid in the wave moves back and forth, so to transmit properly the wave through the outflow boundary, you need to allow the velocity at the boundary to be not just poiting in the outward direction, but also inward at some times when the wave is passing through the boundary.
This is the only time one would use this option.
MuxaB is offline   Reply With Quote
Old   July 18, 2013, 15:48
Geo Sebastian
me_geo is on a distinguished road
Hi Guys,
I have a question with regards to outflow boundary condition,its mentioned in the manual that outflow BC should'nt be used if there is backflow,does anyone know the physical reason for this statement?
me_geo is offline   Reply With Quote
Old   July 19, 2013, 02:44
michael barkhudarov
Originally Posted by me_geo View Post
Hi Guys,
When fluid enters at a boundary, it should carry with it physical quantities such as velocity, pressure, temperature, etc., which are specified. At an outflow bc none of those can be defined by the User hence an incoming flow has no physical meaning.
Mathematically, the reason is that the values of those quantities are calculated by solving a transport equation at the boundary, which assumes the flow is leaving the domain. If the flow is entering instead, then it contradicts that assumption and may result in a numerical instability.
Old   July 27, 2013, 03:41
Geo Sebastian
Hi MuxaB,
thanku for the reply
Old   July 29, 2018, 09:45
TAN SHENG AN
samtan195@gmail.com is on a distinguished road
i have a question,can outflow boundary used for inlet boundary condition?
If yes what is the setting?
samtan195@gmail.com is offline   Reply With Quote
Old   July 29, 2018, 20:55
michael barkhudarov
I am not sure what are you trying to model, but there is an option to allow fluid to re-enter at the outflow BC:
NAME DEFAULT DESCRIPTION UNITS IOBCTP(n) 0 Reverse flow option at outflow mesh boundary #n (of type 8)
=0, do not allow fluid to enter the domain at the boundary
=1, allow fluid to enter the domain at the boundary (useful when modeling linear surface waves exiting at this boundary)
NONE
Old   July 30, 2018, 00:12
TAN SHENG AN
Thank you very much,MuxaB
I am using it for propeller simulation to investigate its effect on sediment transport
Previously i used specific velocity for inlet but it blow away my sediment layer, but it was too strong and blow away my sediment straightaway
Old   July 30, 2018, 10:37
michael barkhudarov
Could you use a pressure BC instead? That would be more physical. Using an outflow BC for inflow is not a good practice since it may generate instabilities, but you can always try.
Old   July 30, 2018, 12:07
TAN SHENG AN
Thank you for you explaination, MuxaB
Just another additional question, if for my simulation case, it will be more suitable to use symmetry or pressure or outflow for the side boundary?
Currently i using outflow boundary, but i afraid the fluid fraction will reduce throughout the experiment( as i am request to maintain the fluid fraction at nearly constant)
Old   August 29, 2018, 22:50
michael barkhudarov
Hi, Sorry for a much delayed response. You probably figured it out on your own by now, but I will put my two cents here.
It is better to use a pressure BC, with fluid elevation and tangent velocity equal to that of the mean flow. You still need to have some distance between it is the obstructions in the flow to minimize wave reflections.
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
SymmetryPlane Boundary Condition raytracer OpenFOAM Running, Solving & CFD 0 July 11, 2008 18:04
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
Outflow boundary condition in FLUENT Sri FLUENT 5 December 5, 2003 05:42
Supersonic Outflow Boundary Condition asif FLUENT 1 July 26, 2003 12:30
