Home > Forums > Software User Forums > FLOW-3D
Stepped Spillway
Old   February 2, 2010, 07:41
Default Stepped Spillway
Mohammad Sarfaraz
mohammad.sarfaraz is on a distinguished road
Hi
I want to model a stepped spillway in FLOW-3D.
Has any one done this before? or
does any one have a thesis about this?
mohammad.sarfaraz is offline   Reply With Quote
Old   February 2, 2010, 10:25
michael barkhudarov
MuxaB is on a distinguished road
It was done at the Hydrology Institute in St Petersburg, Russia, http://www.eng.rushydro.ru/, and presented at a seminar last June. Don't have a reference for the materials themselves, sorry
MuxaB is offline   Reply With Quote
Old   February 2, 2010, 13:05
Armen A. Ghirghidov
Ghirghidov is on a distinguished road
Hi there. I did that. What do you want to know? I am going to make another simulation in couple days.
BTW. Mike I believe I left that materials somewhere in Internet. I could look through where they are or leave them again.
Regards, Armen.
Ghirghidov is offline   Reply With Quote
Old   February 4, 2010, 02:08
Mohammad Sarfaraz
Hi
I was wondering if you could possibly send me the "STL" files and report (containing boundary conditions,...)
Old   February 4, 2010, 04:47
Armen A. Ghirghidov
Hi there. Sorry I can't That's copyrighted spillway and it is not published yet. I just can send you my preliminary simulation. The spillway has simple steps 5x5m. Boundary were very simple, just use water heights at right and left BC.
Old   November 17, 2010, 19:14
fth
fh
fth is on a distinguished road
hi
i recently saw your messege, i like to know if you could model a stepped spillway in flow 3d and if yes i would be grateful if you could direct me in this regard.
thanks
fth is offline   Reply With Quote
Old   November 18, 2010, 05:29
Armen A. Ghirghidov
Dear fth.
I used spillway with 5x5m steps. There is about 40 steps. so if you need just simulate spillway you will need about 5 cells per step but if you need more information (k and у parameters etc.) you will need about 15 ceels per step. For example I calculated that spillway about 20 days with 5 cells per step on Core 2 Duo. The same spillway with 15 cells is simulating about 30 days on Core-i7 (it's about 4-5 times faster) and it's quite far from the end. :-( Many things depends on you computer.
About BC I wrote above.
Regards, Ghirghidov
Old   November 18, 2010, 08:56
Wink Stepped Spillway
Mohammad Sarfaraz
Hi there
As I read Ghirghidov's message, I think that a stepped spillway with the 5m height of the steps, is not a real case!
The maximum height of steps that has been constraucted is 1.2m.
I have modeled a stepped spillway which the height of the steps is 1.2 m, the slope fo the spillway is 1.2V:1.0H and the height of the spillway is 82.0m, both physical and numerical. The numerical modelling was done by FLOW-3D. After all the numerical results agree very well with the physical modelling results.
Old   November 18, 2010, 09:25
Armen A. Ghirghidov
Dear Mohammad Sarfaraz.
I'm sorry I was not right. there are steps 1.5x1.5 etc. Actually that spillway contains steps with different configurations - several 0.5x0.5 one about 5 (or 6) and others 1.5x1.5.
Regards, Ghirghidov.
Old   November 18, 2010, 11:15
Default Tech paper
Daniel
Davahue is on a distinguished road
Originally Posted by mohammad.sarfaraz View Post
Hi
I found this time ago
I hope it helps,
http://www.flow3d.com/pdfs/tp/wat_en...i-Bib33-10.pdf
Davahue is offline   Reply With Quote
Old   June 12, 2011, 15:31
Azam Dolatshah
matilda is on a distinguished road
Regards, Armen.
Hi. Mr. Armen
would you please send me your perpin file to khow how i set the condtions? i want to khow what the mistake is that the simulation doesn't do well (the water jumpe over the steps actually in my simulations)
thanks
A. Dolatshah
matilda is offline   Reply With Quote
Old   June 14, 2011, 07:14
Armen A. Ghirghidov
Dear Azam Dolatshah,
send you to where?
Regards.
Old   June 15, 2011, 08:13
Azam Dolatshah
send you to where?
Regards.
Hi Dear Armen
please send it to this e-mail adress : matilda_wkb@yahoo.com or matilda.wkb@gmail.com
i'm very glad for your kindness,
thank you very very much...
best regards
Old   July 6, 2011, 02:32
Default Article
  #14
Mohammad Sarfaraz
I have found this article useful, modeling stepped spillway with FLOW-3D.
https://rapidshare.com/files/2753917293/Sarfaraz.pdf
Old   July 6, 2013, 11:51
Default input file
  #15
ali pourali
a.pourali is on a distinguished road
hi can you help me with sending the geometry and input file of stepped spillway simulation.
this file is available in flow-3d user's site but i can't access that for log in password problem
a.pourali is offline   Reply With Quote
Materials / Tutorials for simulating flow over spillway basud0817 FLOW-3D 4 August 25, 2015 05:39
fluent using for spillway heidari,m FLUENT 4 July 22, 2011 02:44
Flow Over a Spillway Nicopep OpenFOAM 1 October 21, 2009 05:48
Spillway modelling: doubt about dimension arsatan80 FLOW-3D 1 August 5, 2009 12:00
Spillway symulation Ghirghidov FLOW-3D 3 May 15, 2009 10:33
