Home > Forums > Software User Forums > FLOW-3D
For shrinkage simulation
Old   January 13, 2010, 01:37
Post For shrinkage simulation
zhou le
zhoule0130 is on a distinguished road
I want to simulate the shrinkage for gravity casting. I have the .stl file of the castings (shown in the attachment).
For flow3D, it cant allow use multi-mesh to simulate the shrinkage, but I want to use it, because it can conform the real situation.
So how can I solve for this problem?
zhoule0130 is offline   Reply With Quote
Old   January 20, 2010, 12:30
michael barkhudarov
MuxaB is on a distinguished road
You are right that currently, the shrinkage model only works in a one mesh block environment. What you can do to minimize your mesh is use the domain removing geometry components, IFOB()=5. All mesh inside these components is removed from memory and calculation.
MuxaB is offline   Reply With Quote
Old   May 15, 2010, 17:11
zhou le
Thank you. but i dont understand ifob()=5? how can i set it?
i can upload the .stl file to you.
Can i have any contact of you?
My email address is : le.zhou@gkss.de
Thank you very much!
Old   May 15, 2010, 19:21
michael barkhudarov
Zhou,
You need to define a new component with the shape of the region you want to deactivate and call it Domain Removing in the GUI, which translates to the setting of IFOB(n)=5 for that component #n. All cells blocked by this component will be deactivated.
How come you are using such an old version of FLOW-3D?
Old   May 20, 2010, 20:35
zhou le
Zhou,
Thanks your replying!
and i have another question, that is how can i model thermal stress using elastic model. I read a paper about the hot tearing, the author used the Magama software to simulate the hot tearing and the damage. they cna get the vov mise stress, and other data which is useful prediction the hot tearing susceptibility.
Old   May 20, 2010, 20:46
zhou le
Zhou,
because of limited of upload, i cant upload the paper for you , so i list the name of the paper:
prediction of hot tear formation ina magnesium alloy permanent mold cating.
This is subject of my PhD, so i really want helo from you.
I think flow3d can do it also.
Old   June 9, 2010, 16:27
michael barkhudarov
Hi Zhou,
There is not enough room on thvis forum to explain such a broad topic as modeling stresses and strains in FLOW-3D. This capability has become available in version 9.2.
I suggest contacting your FLOW-3D support to get the information.
Old   November 11, 2010, 10:17
Yang Yue
therockyy is on a distinguished road
Zhou,
'cause there is pirated version of Flow-3D v9.3 online... It's just a guess
therockyy is offline   Reply With Quote
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 14:24
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 02:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
