November 24, 2009, 04:59 |
BC for pipe that connecte to the pump
Atiieh Rostami
Rep Power: 17 |
Dear experts
I want to simulate a pipe that connected to a pump. the water in pump is not impotant for me. I want to model the pipe only. Can I use the pressure B.C. for boundary that water remove the computational domain, from the pipe to pump? can I use the minus pressure(P<0) at this boundary? do i use the stagnation pressure or static pressure? Regards Ati |
November 29, 2009, 19:57 |
michael barkhudarov
Rep Power: 18 |
Ati,
Yes, you can use a pressure BC at the outlet, including a negative pressure. For consistency, you should use either fixed static pressure at both inlet and outlet, or have a flow rate defined at one boundary and static pressure at the other. Michael |
Pump Station Simulation | GUSU | CFX | 6 | October 14, 2009 07:40 |
Regenerative pump modelled in FLOEFD pro | YYY | FloEFD, FloWorks & FloTHERM | 2 | October 5, 2009 06:04 |
A pump paradox | bearcat | Main CFD Forum | 7 | July 14, 2009 21:02 |
pump as a momentum source | PriA | CFX | 4 | October 23, 2007 08:53 |
Discharge pump flow | Ali | Main CFD Forum | 0 | March 5, 2003 18:11 |
