Regarding Implementation of Hershel Bulkley Model in Viscosity correlation |
August 24, 2009, 07:34 |
Nitin Pathak
Rep Power: 17 |
Hello I am trying to simulate the filling of A356 alloy in semisolid state using Flow 3D. Although Flow 3D has module for semisolid filling with viscosity model of Carreau Model. But I am using Herschel Bulkley's (HB) model for modelling viscosity.
According to HB model, following is the expression for shear stress. tau = tau_0 (f_s) + exp (B f_s) * k * (gamma_dot) ^ n -------------(1) from experiments we have determined values for tau_0, B and k for different solid fraction (f_s) say for f_s = 0.25, 0.4 and 0.5 etc. so if the equation (1) is divided by gamma_dot (which is shear rate) then it will give apparent viscosity. and further terms can be rearranged matching with the corresponding carreau model in flow 3D. Like matching tau_0 (f_s) / (gamma_dot) will be equivalent to lambda / gamma_dot so tau_0 (f_s) will be equal to labda. similarly other terms can be matched and values can be fed. but i want to ask how gamma_dot is going to be calculated because the viscosity is dependent upon gamma_dot (ie. shear rate also). How this can be given as input??? |
non-linear k-epsilon model implementation problems | Saidi | Main CFD Forum | 2 | March 4, 2010 14:23 |
effective viscosity in RNG k-e turbulence model | Ellen | Main CFD Forum | 1 | August 20, 2002 03:20 |
Biharmonic Viscosity with Smagorinsky model | Wen Long | Main CFD Forum | 4 | May 15, 2002 06:54 |
Need Assistance: BCs for k-e model implementation | Dean Schrage | Main CFD Forum | 3 | August 11, 2001 02:02 |
A reference on implementation of Spalart-Alam. Turbulence Model? | Mohammad Kermani | Main CFD Forum | 2 | December 26, 1999 03:56 |
