Home > Forums > Software User Forums > FLOW-3D
Spillway modelling: doubt about dimension
Old   August 5, 2009, 09:56
Default Spillway modelling: doubt about dimension
federico
arsatan80 is on a distinguished road
Dear All,
how do you set the dimensions of your Flow3d model?
In the case of Flow over a Spillway, do you model the real dimensions of the
spillway or it is better to scale them?
Thanks in advance.
Fred
arsatan80 is offline   Reply With Quote
Old   August 5, 2009, 12:00
H.C
H.C is on a distinguished road
it might be preferable to model the real dimension. thats one of the advantages using CFD instead of doing experiment. if you scale the geometry in CFD or experiment, you most likely will also need to scale the flow velocity, fluid properties, etc.
H.C is offline   Reply With Quote
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 12:37
doubt regarding channel critical dimension anandan FLUENT 0 September 23, 2005 01:55
how to ensure that your modelling is correct rvndr Main CFD Forum 7 March 1, 2004 13:21
Computational Modelling of Vortex Separators May Lim Main CFD Forum 6 November 13, 1998 13:36
