Home > Forums > Software User Forums > FLOW-3D
About probe result of Wave simulation
Old   March 11, 2009, 21:52
Default About probe result of Wave simulation
shiw
I set a wave simulation input file of Flow3D with a 0.7m Height wave incidence(i.e. wave amplitude is 0.35m),and the water depth is 2.0m in the area,the Finish time is set to 200s.then I render a probe data of free surface elevation from the result, I got a wave line of the water depth at this probe point, but the water depth of this point has a little decrease with the increase of time, in begeinning, the water depth is 2.0m and the wave heigh is about 0.6m, but in the end of the time, about 180s, the water depth is just about 1.2m, what's the reason of that?
Old   March 12, 2009, 15:25
Default Re: About probe result of Wave simulation
HC
where is the relative location of the probe point in the domain? is it very close to the downstream boundary? what kind of boundary conditions did you use in the simulation? if you use the outflow boundary condition at downstream in v9.3.*, did you check the box "Allow fluid to enter at outflow boundary"?
what about the elevation versus time at some point that is very close to the wave boundary?
Old   March 13, 2009, 01:31
shiw
The probe point is in the center of the domain, and I check the"Allow fluid to enter at outflow boundary", too. Could you sent me a email ,so I can post a image and sent you.
Regards!
Old   March 13, 2009, 10:15
HC
so have your checked the point that is somewhat close to the wave boundary?
please try extending the domain in the downstream direction and applying the split lagrangian VOF method, to see if there is any difference.
How to separate two waves in my simulation result? hadesmajesty Main CFD Forum 0 October 13, 2009 01:42
Water wave simulation anil FLUENT 2 August 25, 2005 09:49
Boundary condition, UDF, Wave simulation hm FLUENT 0 August 2, 2004 22:45
Breaking Wave Simulation Mehdi BEN HAJ FLUENT 0 February 9, 2002 13:31
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
