Home > Forums > Software User Forums > FLOW-3D
Need support for GAMBIT geometry
Old   February 18, 2009, 21:59
Default Need support for GAMBIT geometry
srbbd
In my research , I need to do a CFD model using GAMBIT and FLUENT. My flow is water and this is an open channel flow. I draw geometry in GAMBIT up to face stage. I considered x, y and z value and I have 7 faces. My query is: (1) Do I need to do 2D modelling or (2) 3D modelling. (3) In case of 2D or 3D modelling what I need to do next?
If you need any further information, please let me know. I am eagerly waiting for your reply.
Old   March 9, 2009, 15:26
Default Re: Need support for GAMBIT geometry
Navin
What is the type of crosection of the channel.. If you want a square / rectangular channel.. 2D is enough, but to consider the wall roughness and precise values you need to do a 3D modelling, more over If it is a circular pipe or channel u must use 3D model.
Define the Boundary Conditions in Gambit Inlet - Velocity / Presuure Inlet (as you may wish) Outlet - Pressure outlet / Outflow (as per your requirement) Wall - rest all surfaces that constricts the flow.
Then Define the Continum as Fluid Export the Model as a Mesh file.. Then you must be ready to start setting up an problem in Fluent.
I hope this was informatory, any Further queiries mail me..
Old   March 9, 2009, 23:15
srbbd
Hi Navin
thanks for your reply. I need lot of advise regarding GAMBIT & FLUENT as I am very new in this area.
Could you please provide me your email address so that I can send photograph of my model shape. My email is: srbbd@yahoo.com. I tried to send your gmail address but that email bounce back with message "permanent fatal error".
Your help will be highly appreciated. & I am waiting for your reply.
Old   March 12, 2009, 20:16
srbbd
Navin, your email is not working, could u pls have a check. I tried so many times to send an email but it bounce back. my address is srbbd@yahoo.com
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
