Home > Forums > Software User Forums > FLOW-3D
esqr - definition changed from version 9.2 to 9.3?
Old   February 8, 2009, 15:51
Default esqr - definition changed from version 9.2 to 9.3?
Andreas
I am using customized routines, which evaluate the generalized strain variable ESQR (see mucal.f). When I stepped from version 9.2 to 9.3 the code did'n work anymore. It seems that ESQR produces different values. Was ESQR changed from 9.2 to 9.3? Any comments?
Old   February 9, 2009, 00:23
Default Re: esqr - definition changed from version 9.2 to
michael barkhudarov
Andreas,
Yes, ESQR in 9.3 denotes the square root of the second invariant of the strain rate tensor. Before, it was the invariant itself.
Michael
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie OpenFOAM 10 April 19, 2021 19:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 12:57
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie Main CFD Forum 1 April 19, 2010 15:00
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
