Home > Forums > Software User Forums > FLOW-3D
Results Plotting
Old   February 2, 2009, 05:06
Default Results Plotting
CK
All Does anyone know how to plot both solid temperature (iso surface plot) and fluids velocity vector plot (cut plane) in Flow3d 3D post processing domain?
Old   February 2, 2009, 11:54
Default Re: Results Plotting
HC
Not sure about your question. Do you need both fields in one 3D plot?
If not, for solid temperature, you may choose "Complement of Volume fraction" as iso-surface and have "Wall temperature" as the contour variable. For velocity vector plot at some cut plane, if the cut plane is not aligned with X-Y/Y-Z/X-Z plane, you may have to use some 3rd-party software like Tecplot etc.
Old   February 3, 2009, 08:28
CK
Hi HC yes i'm referred to both results plot into single 3D plot. so is there a way to do it? i don't have third party post-processing software as you mentioned.
xy plot help -- large variation in results alemenchaca Main CFD Forum 0 May 17, 2009 14:45
Backup results in steady simulation Li CFX 0 July 9, 2007 06:39
Real-time residual and results plotting simone Marras Main CFD Forum 6 January 29, 2007 08:57
Circular miniFlume experimental amp numerical results amelia OpenFOAM Running, Solving & CFD 11 September 4, 2005 23:42
Plotting Results on CFX-Post Claudia CFX 0 November 19, 2002 12:09
