Home > Forums > Software User Forums > FLOW-3D
WaveTank
Old   January 15, 2009, 13:04
Default WaveTank
MAB
when simulating Water Waves in a Wave Tank. I wonder which option is best for front and back boundary. Say you have left boundary as Inlet. Right as outflow. Now front and back can either be WALLS or SYMMETRY boudaries. which one is best for wave's propagation from your experience. Thanks in advance
Old   January 16, 2009, 01:52
Default Re: WaveTank
michael barkhudarov
The main difference between a symmetry and a wall boundary is that there is no friction at the symmetry boundary. If you are doing a 2D simulation, then you should use symmetry on the front and back. You would use the wall-type BC if that wall represented the actual wall of the tank.
Michael
Old   January 16, 2009, 06:33
MAB
Thanks Michael. In couple of cases( not all) I noticed that water level rises after 10 or 12 seconds even with Outflow BC implemented on the downstream end ( with Allowing fluid to enter from outflow). Could you suggest any remedy for this. Thanks again.
Old   January 21, 2009, 10:22
michael barkhudarov
How much does the level rise? There were some improvements in the latest release, 9.3, for volume conservation in such cases - what version are you using?
Old   January 21, 2009, 11:03
MAB
I am using v 9.3.1 ( the latest version). I think it rises gradually up to 5mm(or more) in a case of 30s .
Old   January 27, 2009, 10:12
michael barkhudarov
There is generally no guarantee that the amount of fluid entering at a wave boundary is exactly the same as that leaving at the outflow boundary. The mismatch maybe worse for shorter and higher waves. How many wave periods are in 30 seconds in your case?
Michael
Old   February 3, 2009, 01:26
michael barkhudarov
Over how many wave periods?
Old   February 3, 2009, 07:07
MAB
Thanks...I am currently using a wave of period 1s.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
