January 12, 2009, 08:01 |
about boat simulation
hello
i would like to ask some things about boat simulations, firstly if the software is good enought for the user to calculate the hydrodynamic drag and the results if there are good enought, it would be very good if i can have the advice of a boat expert analist to tell me if he made the simulation and then the real expiriment and how much % different have the results. i also would like to ask if the people of the shipyards are using simulation software for the design of the hull, or using tables??? i would like to have answers from people that already have expirience, we are going to spent a loto of money on this . best regards hasim |
January 14, 2009, 04:00 |
Re: about boat simulation
hello hasim, we do boat simulations, and recently we are performing calculations comparing the numerical FLOW-3D results with experiments on sailboat and motor-planning hulls too. I can tell you that with a good setup and making simulations of 2 dof coupled motion hulls, you can reach an accuracy of the 0.1° on the pitch angle, less than the 0.1% (about the lenght of the hull) on the heave, and less than the 4% on the total force vs the experiment. You can ask whatever you want, we'll be glad to help you.
January 14, 2009, 07:38 |
less than 4% !!!!!! thats a great number.
can i ask some more questions? you said sailboats!! so in sailboat are you using vof with two fluids? i mean that we can calculate the aerodynamic and hydrodynamic at the same time? with 6 DOF??? thanks |
January 14, 2009, 07:58 |
yes, you could, but it will be very computationally expansive and with some limitations. (in the end probably it will not be convenient to you such simulation) When I spoke about sailboat I mean that we simulate just the hydrodynamic part, in bare hull configuration. Where are you from?
January 14, 2009, 18:02 |
turkey
January 14, 2009, 18:07 |
i have also a qustion in the main forum about the hydrodynamic of the ships, please take a look of it and tell me your opinion since you are more exprt on the flow 3d software ( we do not know this software)
January 15, 2009, 02:58 |
sorry hasim, but I can't find your previous message in the main forum. If you want you can reply here the question.
January 15, 2009, 04:38 |
hello
there is been a spam attack to the main forum, you will see them after the restore of the messages. hasim |
January 19, 2009, 22:18 |
#9 |
Stefano,If simulate the wave generated by ship, how should I set the F3D?I set the Gravity, Moving and deforming objects, Viscocity and turbulence in physics tab, and in Meshing_Geometry, set a Gmo moving from left to right.
Is it enough for simulating ship wave? |
January 22, 2009, 10:52 |
#10 |
what do you mean by ship wave? If you want to simulate the ship when hits a wave, then you have also to set up the "wave" boundary condition at the inflow boundary.
January 24, 2009, 02:45 |
#11 |
No, I mean that wave generated by a ship in the river. So tell me how should I set the Inputfile.
Thanks. |
January 26, 2009, 03:16 |
#12 |
then the setup that you wrote should be enough to see the wave pattern generated by a moving boat. What do you see? The boat moves without generating waves?
March 29, 2010, 09:34 |
Regarding accuracy in ship resistance calculations
#13 | |
Kjetil K. Heggernes
Rep Power: 16 |
Your results sound quite impressive. Maybe you aware that there is a tech paper on validation of Flow-3d for flow around a ship hull posted on Flow Science's web page, dating back to 2006. Here, the frictional resistance is severely overestimated. I would like to think that this is partly due to poor setup, but I fear that Flow-3d's meshing strategy can make it dfficult to predict the aft ship separation for a conventional displacement hull with sufficient accuracy - unless you use an excessive amount of grid cells. Do you have any comments? I would really like to see a benchmark computation of Flow-3d for this type of problem that disproves the poor results reported in the paper mentioned above. Regards, Kjetil |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
about boat simulation | hasim | Main CFD Forum | 22 | January 22, 2009 16:39 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
