Home > Forums > Software User Forums > FLOW-3D
SMP Scaling Capabilities
Old   January 12, 2009, 00:01
Default SMP Scaling Capabilities
CK
All I understand that scaling for SMP version is limited beyond 4 CPUs. so, have anyone tested beyond 4 CPUs and anyone know if this issue will be resolve in v9.4?
Old   January 14, 2009, 11:43
Default Re: SMP Scaling Capabilities
michael barkhudarov
CK,
It is becoming common to run on 8 processors, scaling is reasonable, but not outstanding, factor of 3-4 at best. The scaling is sensitive to the physical and numerical models selections, mesh size and dimension.
No dramatic improvement is expected in 9.4, but work is under way to extend SMP scaling beyond 8 threads.
Michael
Old   January 14, 2009, 23:03
CK
Michael Noticed GMO only allow to run in serial processing thus not able to fully utilize the SMP feature. so, will it still speed up if run at 4 cores?
Old   January 16, 2009, 01:49
michael barkhudarov
You are right, the GMO model is still largely serial, but combined with the parallelized fluids solver, should still scale. Most part of the fluid motion solution have been parallelized.
Michael
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 04:52
Water mist modelling capabilities of any software. Iqbal Main CFD Forum 4 January 17, 2011 02:15
Water mist modelling capabilities of any software Iqbal CFX 2 January 13, 2011 20:00
Water mist modelling capabilities of any software. Iqbal FLUENT 0 January 13, 2011 03:59
SMP scaling with surface tension problem ck5285 FLOW-3D 4 August 24, 2009 10:25
