January 7, 2009, 12:49 |
Postprocessing - Create JPEG's without GUI.
I would like to know if Flow-3d can automatically create 2-D images at the end of a simulation without opening the gui to render them. At the end of a run, I would like to have images of 10 time slices by 30 cut planes (300 images). I am running Flow-3d remotely on a machine that does not have a graphis card. Thanks in advance, Frank D. |
January 9, 2009, 01:06 |
Re: Postprocessing - Create JPEG's without GUI.
Frank, I do not know if current versions can make jpegs, but older versions could make bmps (bitmaps). I do not see that option in 9.3.1 help files. You probably should set up a short test run to be sure it works the way you want to.
I recommend you go to the help files/manual, and look up INPUT VARIABLE SUMMARY > GRAPHIC OUTPUT (GRAFIC) > Graphic Output: Contour Plots to learn how to set up the plots. Then look in the help files TUTORIAL > RUNNING FLOW-3D > Running FLOW-3D from the Command Line > Display program: PLTFSI and FLOWPLOT Good luck! Jim Higgs |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 10:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
