Home > Forums > Software User Forums > FLOW-3D
STL File Creat tools
Old   January 7, 2009, 05:31
Default STL File Creat tools
ShFlow
I want to know that Which CAE Tools is the most suitable one to creat STL file for Flow 3D?
Solidworks, UG, ProE...?
Old   January 7, 2009, 23:33
Default Re: STL File Creat tools
CK
ShFlow any MCAD tools such as Pro-E, Solidworks, SolidEdge, UG,...can be used to create STL files for Flow-3D. So far i didn't encounter major issue with SLT import for Flow-3D
Old   January 8, 2009, 21:51
fathan
hai, i use AUTOCAD 2007 for create STL n ihave no worry bout that
Old   January 9, 2009, 01:25
ShFlow
Thanks! Yes, I try to use Autocad to make STL for Flow3D, It seems no problem at all.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
