Home > Forums > Software User Forums > FLOW-3D
How to define the wall roughness in FLOW-3D ?
Old   December 19, 2008, 04:31
Default How to define the wall roughness in FLOW-3D ?
Marco
I'm researching about open channel flow, and the roughness is an important role in open channel. But I don't find where can I set the roughness in FLOW-3D. May Someone help me to solve the problem ?
Thanks a lot.
Old   December 19, 2008, 09:43
Default Re: How to define the wall roughness in FLOW-3D ?
Armen A. Ghirghidov
You may use rough(1)=0.001 (roughness in meters) for example in $obs part of the prepin.inp or use Geometry->component->surface properties->surface roughness and remember that roughness in meters (if you use si system of course). FLOW-3D help has full information about this.
Regards, Armen
Old   December 19, 2008, 16:15
AMP
It is very easy, F3D get these datas where you define a new obstacle with special material properties in geometry menu.
Old   December 20, 2008, 02:26
Marco
Very grateful everyone. I'll try again, thanks.
Assigning Wall Roughness in STAR-CD Sachin Siemens 1 March 11, 2008 12:24
Assigning Wall Roughness in STAR-CD Sachin Patil Siemens 0 March 6, 2008 04:05
sos! How to define the flow rate of outflow BC? zjm FLUENT 0 June 4, 2004 10:12
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
