Home > Forums > Software User Forums > FLOW-3D
GRAPHIC RESULTS
Old   December 18, 2008, 16:26
Default GRAPHIC RESULTS
AMP
for core casting simulation, is it possible to view the core in flowvu? core hase been defined as a separate obstacle, in stl format.
Old   December 23, 2008, 06:03
Default Re: GRAPHIC RESULTS
Stefano
you can load the .stl in the flowvu window. Can it be enaugh?
Old   December 23, 2008, 09:47
AMP
unfortunately I can not view stl files within the file menu (stl viewer) as you said. it appears and suddenly disappears. I have been installed F3D several time but it couldn't be useful.
Old   January 7, 2009, 04:02
Stefano
you should think to upgrade to a newer version then. FLOW-3D has introduced version by version new features regarding the .stl importing: since 9.1 (or maybe earlier) you have an .stl loader, and in 9.3 you have an automatic .stl loader that it is great!
Old   January 9, 2009, 22:09
AMP
I see, thanks
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
Velocity spots in openFoam results Valle OpenFOAM Running, Solving & CFD 4 August 19, 2009 06:53
How to plot a function over a time period? Cirion0000 CFX 4 July 18, 2009 13:48
how to view the complete results shokry FLOW-3D 5 February 3, 2009 14:56
