Home > Forums > Software User Forums > FLOW-3D
Solid Surface and Fluid Results Plot
Old   November 8, 2008, 09:23
Default Solid Surface and Fluid Results Plot
CK
All is anyone know how to plot both solid preesure/temperature and fluid pressure/temp into one single result plot?
Rgds CK
Old   November 11, 2008, 20:02
Default Re: Solid Surface and Fluid Results Plot
HC
For 2D temperature plots, first render the fluid temperature. Then go to Analyze>Custom, select flsinp.tmp from the drop-down box and click the Save as button to save it as flsinp.tn. Render the wall temperature and go to Analyze>Custom, select flsinp.tmp from the drop-down box and copy the first &pltreq section. Select flsinp.tn from the drop-down box and paste the &pltreq section after the 1st &pltreq section in flsinp.tn. Change advfrm in the 1st &pltreq section to zero and drwfrm in the 2nd &pltreq section to zero, and click Render>2D. In above, it is assumed that no vectors or particles are plotted.
For more information, please search advfrm and drwfrm in the mean Help>Content.
Old   November 12, 2008, 01:32
CK
Hi HC sorry i should clarify my question, i'm actually refering to 3D overlay plot for both solid and fluid properties (eg: temperature, pressure,...). so, is there a way to do it for 3D plot?
Rgds CK
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 12:41
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
