Home > Forums > Software User Forums > FLOW-3D
Confined Flow Problem
Old   October 23, 2008, 05:11
Default Confined Flow Problem
Dan
Hi All Have anyone use Flow-3D for steady state confined flow before? (even though Flow-3D use unsteady RNS and not a real stead state solver). I found out simulation time is extremely longer ~30hrs to reach steady state. so any experience to share or input on this issue?
Rgds Dan
Old   October 23, 2008, 09:31
Default Re: Confined Flow Problem
Stefano
hello, did you tried by selecting an implicit method? (for example the "implicit advection") it may run faster, reaching the same steady state condition. (however check it)
Old   October 24, 2008, 02:48
Dan
Stefano i did try all the implicit method available for this turbulent flow + confined flow problem. But, it still took ~20-30hrs to reach steady state. Btw, did you model this kind of problem before? any advice?
Rgds Dan
Old   October 24, 2008, 03:45
Default Re: Confined Flow Problem - improve the speed.
Stefano
yes, we did some works on confined flows in the past. If your problem is 3D then maybe 20-30hours are not so strange, or better, your setup (basically the mesh that you draw) don't allow you to go faster. Maybe I can help you a little bit in understanding the speed limit of your simulation, but you'll have to help me in this: open the "solver summary" file, periodically you have a block of lines starting with something like "explicit x-advection stability limits =....". Find the most recurrent block of lines and paste me it here. (if you have the solver summary file coming from a simulation with explicit methods it would be better!)
Old   November 4, 2008, 05:42
Dan
Hi Stefano sorry i'm out of office for few weeks. anyway, i noticed flowsicene did provided some tips for steady state confined flow problem in recently Fall 2008 news. anyway, it help in reduced iteration for pressure but doesn't help in cycles count as below. so, do you have any better recommendation?
t cycle iter dtstbl/code delt epsi cpu clock
--- ----- ---- ----------- ---- ---- --- ----- 0.00E+00 0 0 1.94E-04/cz 1.00E-05 -1.0E+00 2.4E+01 21:07:59 5.74E-02 364 1 8.06E-05/vs 8.06E-05 1.1E+06 2.7E+03 21:22:05 2.00E-01 1695 1 1.24E-04/vs 1.24E-04 7.2E+05 1.3E+04 22:13:26 4.00E-01 3379 1 1.15E-04/vs 1.15E-04 7.5E+05 2.5E+04 23:18:42 6.00E-01 5163 1 1.09E-04/vs 1.09E-04 7.8E+05 3.8E+04 00:27:55
Old   November 4, 2008, 09:41
Stefano
hello Dan, from the lines showed it seems that your simulation speed is limited by the viscous calculation (/vs code, near the time-step). So you can turn explicit all the physical models except for the viscous one. If you use an implicit method for viscous calculation it should run faster.
If you run the simulation again with this change, you should not see anymore in your solver message the /vs code, but other /.. codes, and the use of a larger time-step.
Let me know if it works,
Old   November 5, 2008, 02:57
Dan
Hi stefano I don't have a choise of switching to implicit viscous solver as it is not allow for turbulent flow problem. Thus, it become a limiting factor for my steady state confined flow problem. So, do you have any good inputs on this problem?
Dan
Old   November 5, 2008, 03:47
Stefano
On the last FlowScience newsletter there are suggestions on how to reach faster a steady state condition! Following their suggestions in the numerical panel you can speed up your simulation up to 10x. I think you can try it.
And if your fluid flow is turbulent then try to set a TLEN value. As far as I know, sometimes, if you don't set it, the viscosity get excessive values, limiting you excessively the simulation speed with the code /vs.
Old   November 6, 2008, 09:13
Dan
Hi Stefano I did all the recommended sovler setting (SRO solver and relaxation setting) and also key in TLEN value. But unfortunately it still took 30-40hrs for steady state solution. So, I tried with others CFD codes & suprisingly it took only 3-4hrs to reach steady state for the same model! So guess Flow-3D as generic CFD code may optimize for steady state problem.
Old   November 6, 2008, 09:50
Stefano
yes, this is true, or better: flow-3d solver is optimized for transient solutions. If you wanted to solve a transient simulation probably you may get the benchmark at the contrary: 3-4hours with FLOW-3D, and 40hours with others cfd. But I'm sure FlowScience is working also for a dedicated steady state solver...
Old   November 6, 2008, 20:50
  #11
Dan
I totally agreed that Flow-3D has poor steady state solver but not sure about the tarnsient VOF solver. Pls share with me if you have others benchmarck did before on this. Thanks
Old   November 7, 2008, 04:05
  #12
Stefano
hello Dan, I'm glad to write you on that. About the stead-state case, FLOW-3D solver is "time-marching", so you have to reach a steady state condition as in the real world: marching trough the time, starting from an initial condition, untill the flow becomes steady. That's why it may takes more time of a direct steady state solver, but also why I said that for transient solutions is more suitable. (if you simulate 30s for example to reach the steady state solution, the same time almost would have been to make a 30s transient simulation!) About the transient VOF solver: yes, we have done many tests on this. You can have a look at our website (www.xceng.com), in the homepage there's a flash animation of a work that we recently did on a boat that made a World Record. You'll see a very complex simulation with a intensive use of free surface tracking, moving objects, etc... and the time to simulate this was almost like the time you spent to find the steady state solution of your confined flow problem!
Old   November 8, 2008, 09:15
  #13
Dan
Thanks for information sharing but believe Flow-3D may not a suitable option for steady state confined flow problem as it just take too long to reach convergence as compared to others CFD codes. Anyway, the FAVOR option is good for meshing but limited by aspect ratio and multiblock linking error.
Old   November 13, 2008, 13:45
  #14
shahin
Hello Dear All friend I want to use Flow-3D 8.2 for simulation of fluid flow in the submerged nozzle but the solution don't reach to steady state and fluctuate. but if we run this problem with other code same as Fluent we get steady state and correct configuration of fluid flow, where is the problem?
if you want i send you the picture of my simulation... Best Regards
Old   November 13, 2008, 23:47
  #15
Dan
Shahin I believe this is limitation of F3D in simulate steady steady sate confine flow. some time i found out it is not convergence in term of mass flow rate even though the kinetic energy has reach steady trend. So, Fluent should be the right option, no doubt. I had switched to Fluent for my problem and it run 10x faster!
Dan
Old   November 20, 2008, 06:00
  #16
shahin
In pic1( http://shahin1359.tripod.com/pic1.jpg ) you see that after 12.5 second we get good result but after 28.5 sec not only we don't get steady state, we get the wrong result(pic2 http://shahin1359.tripod.com/pic2.jpg)
I use the RNG turbulent model , first order momentum advection, explicit viscose stress omega=1, imp=2, and so on with other variation in the preprocessor else we don't get correct result please help me in this problem!!!!
Old   November 20, 2008, 06:20
  #17
Dan
Shahin i can't open your picture, may be you can try k-e turbulent model. actually i already give up steady state confined flow problem with F3D. you may want to consider to switch to others CFD.
Old   November 20, 2008, 18:19
  #18
shahin
Hi Dear Dan, for open picture copy the address and paste on the browser Address Bar. the k-e model is not correct too I have to do my project with Flow-3D if any one said me this before maybe i did not choose Flow-3D Now do anyone have a suggestion for me?
Old   November 27, 2008, 19:15
  #19
shahin
Hello Dan i think you didn't see pictures please Download this link http://www.mediafire.com/?emyddnzlody
Old   November 29, 2008, 03:19
  #20
Dan
Hi Shahin Sorry i'm not able to help as already give up with Flow-3D and now using Fluent. Structural/rectangular grid/mesh use by Flow-3D some how very easy to mesh geometry however got a lot of limitation as well. Btw, it is not too bad to generate mesh with body fitted mesh (BF) in Fluent. It is more powerful and speed no doubt is at least minimum ~5x faster than Flow-3D in this kind of simulation.
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 06:12
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 01:42
Axisymmetric Vs 2D Flow problem nikhil FLUENT 0 March 30, 2010 00:52
CFX-Post: problem with mass flow Markus CFX 5 February 19, 2005 18:30
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 09:04
