Home > Forums > Software User Forums > FLOW-3D
Advanced FSI Simulation
Old   October 10, 2008, 04:28
Default Advanced FSI Simulation
CK
Hi All, GMO from Flow-3D only allow one direction FSI simulation. Soid deformation/stress due to fluids pressure is not considered. so, anyone know how to export Flow-3D transient fluids pressure to Abaqus or Ansys for advance stress or displacement analysis.
Rgds CK
Old   October 10, 2008, 06:56
Default Re: Advanced FSI Simulation
MAB
something similar is done in
http://www.terrabyte.co.jp/Presentation_flap-gate.pdf
see the last slide. I am not sure what is the procedure..
Old   October 11, 2008, 09:02
CK
MAB thanks for the presentation, but do you have details information on how to transfer the fluids pressure from Flow-3D to Abaqus/Ansys for details stress/deformation analysis?
Rgds CK
Old   November 2, 2008, 23:11
FB Moon
To run abaqus or ansys simulation, you need the node pressure information from the FLOW-3D result. To extract the pressure information in FLOW-3D, you could output the pressure information at the nodes at "Analyze Tab" and "Neutral File Tab". You could have the detail info. in "the on-line FLOW-3D Manual - Exporting Neutral File Data".
Old   November 4, 2008, 05:35
CK
Moon Thanks for the info, but seem like no easy way to incorporate both FEA and CFD solver like Ansys-CFX or Star-CD.
Rgds CK
Old   November 9, 2008, 22:09
FB Moon
Yes, That is true. there is No EASE way. But If you try, you would know that is Not So complicated. There is the other way to use FLOW-3D Text output data. IF You would use your own program to export FLOW-3D data to FEM Solver, you could make it.
FSI Valve simulation FabienBe Main CFD Forum 1 July 24, 2011 17:49
Resume Transient simulation HMR CFX 1 June 28, 2011 22:13
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
1-way FSI Vs. 2-way FSI k_buz Main CFD Forum 0 May 12, 2009 05:10
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
