how to solve the problem that the "negative fluid temperature" |
Yesterday, 03:55 |
Gang Xi
hellow, I use flow3D for SLM. Currently when my heat source is loaded there is a negative flow field temperature. My setup is: 5 um cell , the heat source radius is 35 um, and the laser is set at 350W. And my heat source cause a high temperature up to 1e5 ℃. So how can I solve it? [IMG][/IMG]
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
[ICEM] Problem with mesh outside of fluid domain | derionhobbes | ANSYS Meshing & Geometry | 1 | October 27, 2017 03:14 |
Computational fluid dynamics problem (Matlab) | srik | Main CFD Forum | 0 | May 5, 2013 03:53 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 06:36 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
