Home > Forums > Software User Forums > FLOW-3D
Flow-3D Integration with Matlab Simulink
Old   November 15, 2024, 15:53
Default Flow-3D Integration with Matlab Simulink
Mike F
mfogel is on a distinguished road
Seeking advice on how to modify Flow-3D to dynamically read in angular velocities and linear accelerations from an external table
I am trying to modify the QASDD.F90 Flow-3D file to output forces and torques at specified timesteps, use those forces and torques in a Simulink rigid body dynamics simulation, then the RBD simulation will output angular velocities and linear accelerations which would be read back into Flow-3D.
I have successfully modified the QASDD.F90 file to output the forces and torques and Simulink reads and process them successfully.
I am successfully adding a new line to the Flow-3D "move.inp" file at each timestep.
My struggle in getting Flow-3D to continue reading the move.inp file. It reads in the initial conditions at t=0, t=1, t=2. It will not read further lines past t=2.
Flow 3-D Detailed Log
simulation time went past the motion table in movin file:
last data point will be used for the rest of the simulation
time = 2.00512E+00 last data point at 2.00000E+00
Example move.inp file
0
0.000000 0.000000 0.000000 0.000000 0.031684 0.075485 -0.032106 0.000000 0.000000 0.000000 0.000000 0.000000
1.000000 0.000000 0.000000 0.000000 0.025769 0.051052 -0.017812 0.000000 0.000000 0.000000 0.000000 0.000000
2.000000 0.000000 0.000000 0.000000 0.019948 0.034826 -0.009865 0.000000 0.000000 0.000000 0.000000 0.000000
3.000000 0.000000 0.000000 0.000000 0.014997 0.024005 -0.005278 0.000000 0.000000 0.000000 0.000000 0.000000
4.000000 -0.000314 0.000054 -0.000052 0.010697 0.016656 -0.003476 0.000000 0.000000 0.000000 0.000000 0.000000
5.000000 0.000276 -0.000062 0.000589 0.008675 0.011559 -0.003078 0.000000 0.000000 0.000000 0.000000 0.000000
6.000000 0.000239 0.000241 0.000053 0.005143 0.008030 -0.000441 0.000000 0.000000 0.000000 0.000000 0.000000
7.000000 -0.000143 0.000376 0.000101 0.003469 0.005850 0.002209 0.000000 0.000000 0.000000 0.000000 0.000000
8.000000 -0.000238 -0.000041 -0.000373 0.001659 0.004379 0.001269 0.000000 0.000000 0.000000 0.000000 0.000000
9.000000 0.000153 -0.000421 0.000377 0.002898 0.003239 -0.000148 0.000000 0.000000 0.000000 0.000000 0.000000
10.000000 0.000344 -0.000116 -0.000145 0.001263 0.002308 0.000420 0.000000 0.000000 0.000000 0.000000 0.000000
mfogel is offline   Reply With Quote
flow-3d, matlab, qasdd.f90, simulink
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
Questions about FLOW 3D modeling capabilities Dr Youssef Hafez FLOW-3D 0 January 7, 2023 12:37
Heat and Mass Flow Integration over Slices YASHA Tecplot 2 December 2, 2018 03:34
Couette Flow in Matlab using Pressure Correction Method mulchah Main CFD Forum 4 February 25, 2014 06:41
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
