How to obtain the dicharge of a certain point |
kyla
Rep Power: 2 ![]() |
Can I determine the discharge of a given point or section in flow 3d without using flux surface?
It takes time to run the simulation again so I would like to know if there is a possible shortcut to get the discharge even without flux surface. |
zohran arif
Rep Power: 8 ![]() |
You can get the discharge at mesh extents in probe-> mesh boundary history , other way is to manually calculate using velocity (by flow3d) and area.
[Commercial meshers] Converting fluent mesh to foam | sivakumar | OpenFOAM Meshing & Mesh Conversion | 11 | April 30, 2013 09:29 |
[blockMesh] OpenFOAM blockMeshDict | sihaqqi | OpenFOAM Meshing & Mesh Conversion | 2 | February 1, 2013 03:49 |
[blockMesh] How to use blockMesh to generate cylindrical T-junction | norkistar | OpenFOAM Meshing & Mesh Conversion | 2 | January 28, 2013 20:53 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
