June 3, 2024, 09:51 |
flow depth
Erfan Soltani
Rep Power: 2 |
Hello
I am simulating flow in an open channel, when I use outflow boundary conditions at the outlet boundary, the water depth increases, how can I keep it constant? |
June 3, 2024, 14:50 |
Rep Power: 12 |
Hi.
What is your inlet BC? |
June 3, 2024, 14:55 |
Erfan Soltani
Rep Power: 2 |
Hi dear koful
Inlet is volume flow rate or specified velocity, with 0.12 cm height |
June 3, 2024, 15:07 |
Rep Power: 12 |
If you want a downstream control, choose specified pressure with a specific fluid elevation. If you want an upstream control, you should select outflow bc. So your inlet elevation is 0.12m. How high does the water level rise at the outlet?
June 3, 2024, 15:30 |
Erfan Soltani
Rep Power: 2 |
Thank you
It reaches 0.15 cm and the flow does not reach equilibrium, but when I take a specific pressure with a height of 0.12 cm, the flow reaches equilibrium and the height of the flow is also 0.12 cm. |
June 4, 2024, 04:22 |
#6 | |
kyla
Rep Power: 2 |
Attachment 100188
I used a pressure with specific fluid elevation as BC on the upstream side, I want to get a consistent water elevation to flow through the channel but the water level decreases as it approaches the channel. The BC between the reservoir and channel is symmetry. What should I do to maintain the water elevation in the inlet of the channel? Last edited by kylas; June 12, 2024 at 20:58. |
Flow depth variation problems | er_anas | FLUENT | 1 | April 6, 2020 06:08 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
flow depth in 2D open channel ? | rodi | FLUENT | 7 | January 25, 2011 23:03 |
Default Depth of 2d Flow | M-Ray | FLUENT | 0 | May 20, 2008 03:10 |
