May 23, 2024, 04:05 |
Longitudinal water surface
kyla
Rep Power: 2 |
I would like to make a profile along the centerline of the structure that shows the water surface level and bottom elevation of the structure. I know I can use the slice in Flow 3d Post. But the problem is the structure has so many curves therefore using the regular slice function is not applicable.
How can I do this? |
June 2, 2024, 22:42 |
kyla
Rep Power: 2 |
Can i make centerline profile of water levelusing flow 3d post? or flow 3d?
June 3, 2024, 03:01 |
Sehroosh
Rep Power: 7 |
Hi. Work in Flow 3D post with "Spline source"(blue in image) and extract the data by using filter of your choice in "Data Analysis" as shown in the image
June 4, 2024, 02:20 |
kyla
Rep Power: 2 |
Thank you for your response.
Is there a filter wherein a polyline is made instead of a splice? |
June 4, 2024, 05:56 |
Sehroosh
Rep Power: 7 |
In Flow 3D Post, go to Sources>Geometric Shapes>SplineSource ..... mark a spline following your waterway path and extract the results using "Data Analysis Filters"
Exploding Water Surface (VOF) | JackFischer | STAR-CCM+ | 6 | October 11, 2019 06:14 |
Bubble flow and water surface modeling | sloshing | Fluent Multiphase | 3 | August 24, 2019 04:13 |
how define surface tension of water on aluminum? | zeeshan latif | FLUENT | 0 | April 12, 2015 08:15 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
