How to create mesh block for curved channel in FLOW3D? |
May 17, 2024, 09:12 |
Murali Krishnamraju
Rep Power: 4 |
I am trying to simulate flow in a curved channel in FLOW-3D. But I am struck at creating the mesh block. As shown in the figure, the mesh block is coming as a rectangle, not aligning with the curved channel. The initial water level is also coming over the entire mesh block instead of only in the channel.
How can I correctly create the mesh block and give the boundaries for the curved channel, as shown above? Access figure with this link: https://drive.google.com/file/d/1fuz...8Bm7wFwqc/view |
May 29, 2024, 04:18 |
Rep Power: 12 |
Hi.
Flow3d's can only generate rectangular grids. I am not able to see your images but if you add only your channel geometry water will fill the side empty places between the channel wall and the mesh boundary. you should fill the rest of the mesh with solids. |
June 2, 2024, 21:39 |
kyla
Rep Power: 2 |
Try to change your side boundary(ymin,ymax) conditions to WALL.
You can also set the initial condition of the channel, regions can be interactively edited so it's easier to adjust |
flow 3d hydro, flow 3d post, flow3d, mesh 3d |
[ICEM] Heat transfer in 2D ribbed channel: ideas to address the mesh | jmhaque | ANSYS Meshing & Geometry | 6 | June 15, 2024 00:05 |
[Other] splitMeshRegions does not create interface patch between regions | fsan | OpenFOAM Meshing & Mesh Conversion | 10 | June 6, 2022 05:56 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[ICEM] Replay not working properly - Creating the mesh for Free Block. | Wingman | ANSYS Meshing & Geometry | 4 | January 17, 2017 03:57 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
