Home > Forums > Software User Forums > FLOW-3D
Having problem with restart after power outage
Old   April 22, 2024, 09:34
Default Having problem with restart after power outage
Ontario
IanDunlop is on a distinguished road
Good day, i was running a multiday simulation and of course the power went out about half way through the simulation. I figure i would just set up a restart to finish off the time remaining. But the every time i try and and run the restart i'm getting this error. i've never had an error like this on a restart from a simulation that was running with no errors. its probably something simple that i'm missing.
thank you
Ian Dunlop
i'm using flow3d v11.2
IanDunlop is offline   Reply With Quote
Old   April 24, 2024, 01:55
Sehroosh
MSM1985 is on a distinguished road
Time step < dtmin. ..... the error which can be caused by multiple issues and difficult to track. However i would suggest to
1) Restart simulation from an earlier time step which you are selecting might help to run the simulation.
2) If step 1 doesn't work, Restart simulation from an earlier time step with a bit coarser mesh. When you find model is running stable, you can stop and add another restart simulation with fine mesh of your desire.
MSM1985 is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Problem with restart of unsteady flows using shape_optimization.py Eduardo Carvalho SU2 Shape Design 0 January 30, 2020 15:13
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 20:41
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
Backup & Restart problem Sally CFX 4 November 19, 2005 13:44
