Help me. Warning message: downstream direction not defined |
March 29, 2024, 21:31 |
#1 | |
Yunia
Dear all
I'm a beginner in using flow-3d. I tried to simulate wave and added wave absorber as component. However the simulation didn't run well, it displayed like this "Abnormal exit from simulation". I opened warning box and something like this appeared Quote:
March 30, 2024, 23:12 |
Eric Lemont
Rep Power: 6 |
When you use the wave absorbing component type, in the wave absorbing settings in the component properties window, you need to define XYZ points for the starting point and downstream direction.
April 3, 2024, 11:31 |
Yunia
Thank you very much for the answer. Now the simulation works really well.
#flow3d, #warning, #wave, #waveabsorber, #waves |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? | randomid | OpenFOAM Community Contributions | 1 | August 27, 2010 06:15 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Add icoLagrangianFoam to FoamX | dyxu | OpenFOAM Running, Solving & CFD | 10 | June 11, 2008 10:53 |
