Home > Forums > Software User Forums > FLOW-3D
sediment simulation
Old   March 15, 2024, 09:29
Default sediment simulation
Erfan Soltani
Erfan-s is on a distinguished road
Dear Flow3D users;
I simulated the transport of suspended sediment in a plant environment and when I wanted to see the result of suspended sediment concentration, the contour of suspended sediment in the x, z plane, what is that gray color and why did it appear? Is it a software problem?
In the attached image
thank you
Erfan-s is offline   Reply With Quote
Old   March 17, 2024, 19:11
Eric Lemont
Flow Science Australasia is on a distinguished road
FLOW-3D will update the solid regions each time step based on how much sediment has settled out. It looks like your grey areas are where your sediment is piling up. If you cycle through your time steps, you should notice the grey area evolve over time.
Flow Science Australasia is offline   Reply With Quote
Old   March 18, 2024, 03:11
Default suspended sediment
Erfan Soltani
thanks for your response
There is some solid cylinder in the channel, which in the first picture is 12 meters long, but this does not happen in the smaller section (channel length 3 meters).
Also Z min boundary condition is wall
Old   March 18, 2024, 03:25
Eric Lemont
You can plot the net elevation change of the packed sediment to see how much sediment is collecting along the Zmin boundary. As the packed sediment forms along the bed, it will show up as a grey solid area.
Old   March 18, 2024, 03:57
Default suspended diagra
Erfan Soltani
thank you
Could you please give an explanation about these diagrams and how the numerical range in the vertical grid is obtained? And that suspended sediment mass
thank you
Generating sediment bed and scouring simulation @Chitrangini REEF3D 15 April 8, 2024 21:26
Question on steady and unsteady simulation Stargazer Main CFD Forum 33 December 19, 2023 02:45
Velocity exceeds ajayjatoliya REEF3D 8 July 17, 2023 07:32
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation of high pressure diesel injector - all phases compressible with cavitation fivos CFX 4 July 30, 2015 07:48
