sajad mojtahedi
Rep Power: 2 ![]() |
Hello, dear experts
The simulation stops after some time and the graph(stability limit & Time-step size) reaches zero, what could be the reason for this? |
Robert
There might be some information in the solver message window - what does it say there?
sajad mojtahedi
I put part of the messages inside (solver message window):
restarting cycle with smaller time step 1.27732E+03 12960 4.59E-03 1.02E-02/fs 1 4.25E-01 8.4315E-01 +6.46E-03 0.54 07:40:42 71 00:39:56 convective flux exceeded stability limit at t= 1.2781E+03 cycle= 13058 iter= 2 delt= 8.2209E-03 mesh block 1 restarting cycle with smaller time step 1.27936E+03 13232 5.41E-03 1.02E-02/fs 1 6.50E-01 8.4325E-01 +6.49E-03 0.54 07:50:43 71 00:49:57 convective flux exceeded stability limit at t= 1.2800E+03 cycle= 13310 iter= 2 delt= 7.9311E-03 mesh block 1 restarting cycle with smaller time step convective flux exceeded stability limit at t= 1.2808E+03 cycle= 13412 iter= 2 delt= 1.0203E-02 mesh block 1 restarting cycle with smaller time step 1.28134E+03 13504 3.19E-03 5.55E-03/sy 1 2.92E-01 8.4322E-01 +6.46E-03 0.54 08:00:45 73 00:59:58 1.28211E+03 13808 9.85E-04 9.85E-04/vs 1 1.08E-01 8.4321E-01 +6.48E-03 0.54 08:10:45 69 01:09:59 1.28234E+03 14114 6.13E-04 6.13E-04/vs 1 1.25E-01 8.4322E-01 +6.47E-03 0.54 08:20:47 71 01:20:00 1.28251E+03 14419 4.78E-04 4.78E-04/vs 1 2.81E-02 8.4322E-01 +6.46E-03 0.54 08:30:47 68 01:30:01 1.28264E+03 14724 4.03E-04 4.03E-04/vs 1 2.71E-02 8.4323E-01 +6.46E-03 0.54 08:40:48 54 01:40:01 1.28276E+03 15029 3.55E-04 3.55E-04/vs 1 4.68E-02 8.4323E-01 +6.45E-03 0.54 08:50:49 54 01:50:02 1.28286E+03 15335 3.21E-04 3.21E-04/vs 1 2.53E-02 8.4323E-01 +6.45E-03 0.54 09:00:49 51 02:00:03 1.28295E+03 15642 2.94E-04 2.94E-04/vs 1 3.93E-02 8.4323E-01 +6.44E-03 0.54 09:10:49 52 02:10:03 1.28304E+03 15949 2.74E-04 2.74E-04/vs 1 1.96E-02 8.4323E-01 +6.44E-03 0.54 09:20:50 54 02:20:03 1.28312E+03 16270 2.56E-04 2.56E-04/vs 1 1.45E-02 8.4323E-01 +6.43E-03 0.54 09:30:51 50 02:30:05 1.28320E+03 16590 2.41E-04 2.41E-04/vs 1 2.99E-02 8.4323E-01 +6.43E-03 0.54 09:40:52 52 02:40:05 1.28328E+03 16898 2.30E-04 2.30E-04/vs 1 1.55E-02 8.4323E-01 +6.42E-03 0.54 09:50:53 54 02:50:06 1.28335E+03 17203 2.19E-04 2.19E-04/vs 1 1.22E-02 8.4323E-01 +6.42E-03 0.54 10:00:53 54 03:00:07 |
sajad mojtahedi
The part marked with blue color in the attached image is different among all the messages displayed in the (solver message window)!!!!
At first, I thought it might be a hardware problem, but I tried it with another system and both systems have a problem during simulation when they reach 1280 seconds. ![]() ![]() |
sajad mojtahedi
In order to reach the state of full development in the scouring process of the bridge support, I extended the simulation time to 1200 seconds, of course, in several steps and through the use of the restart time section in four 300-second steps... due to not being realized, I had to I continued until 1500 seconds
I had no problem until 1200 seconds, but after that I have problems at 1280 seconds According to the messages of the solver window, it is clear that the time steps are larger before 1280 seconds, but at 1280 seconds, it seems that the calculation steps become smaller and the simulation time becomes very long. |
Robert
My best guess would be that there is something wrong with your convection settings.
sajad mojtahedi
Hello, thank you for your time
In which part of the software did you put the convection settings, I did not understand what you mean |
Robert
Although it's an older version of FLOW-3D, this might help:
https://docshare.tips/exercises-flow...25e8b4840.html |
#flow 3d, #timestep |
Question on steady and unsteady simulation | Stargazer | Main CFD Forum | 33 | December 19, 2023 01:45 |
Control simulation to apply different fields with chtMultiRegionFoam | jmdf | OpenFOAM Running, Solving & CFD | 0 | February 29, 2016 07:05 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
Fan simulation divergence | ayothicfd | CFX | 18 | July 20, 2012 05:53 |
