Home > Forums > Software User Forums > FLOW-3D
OpenFOAM simulation results converted to Flow-3D post-processing
Old   January 30, 2024, 22:25
Default OpenFOAM simulation results converted to Flow-3D post-processing
esma is on a distinguished road
I asked this question in the OpenFOAM forum but didn't receive an answer, so thought to copy that here to see if it gets any attention. In a nutshell:
I would like to know how the simulation results of OpenFOAM can be converted to a format that can be visualized in Flow-3D. Just wondered if anyone has worked with these two software and knows how. Appreciate any clue.
esma is offline   Reply With Quote
Old   January 30, 2024, 22:58
Perhaps I should have done more research before asking a question here. But here is what I found so far. Please let me know if this will work as unfortunately, I don't have access to Flow-3D software at the moment to check.
In Flow-3D post-processing section says "FLOW-3D POST 2023R2 introduces support for an all-new results file format based on the EXODUS II format, enabling faster postprocessing."
I checked Paraview and in "Save Data" I can see one of the file types being supported is "Exodus II", does that mean I can simply open the results if OpenFOAM in Paraview and save the data as Exodus II then open that file in Flow-3D? Appreciate any input.
Old   January 31, 2024, 01:20
Sehroosh
MSM1985 is on a distinguished road
Hi. Flow 3D Hydro 2023 R2 can read EXODUS file format. However for faster post processing, its better that you open EXODUS files in Flow 3D Post 2023 R2.
MSM1985 is offline   Reply With Quote
Old   August 3, 2024, 03:34
liuyuan
liu228 is on a distinguished road
Can you provide me Flow-3d post progress software,please
liu228 is offline   Reply With Quote
Old   November 2, 2024, 05:25
lixew98079 is on a distinguished road
Converting OpenFOAM simulation results to a format compatible with Flow-3D requires exporting the data into a universal format, such as VTK or CSV, which Flow-3D can read and process. You may need to use OpenFOAM's post-processing utilities like foamToVTK or create custom scripts to facilitate this data conversion.
lixew98079 is offline   Reply With Quote
[OpenFOAM] Using python script for automatic post processing of openFoam vPaquet ParaView 12 December 16, 2021 04:30
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body onlycfd CFX 4 April 29, 2021 04:02
Simulation DNS for two phase flow in openFoam ht2017 OpenFOAM Running, Solving & CFD 0 December 8, 2020 06:50
Lagrangian post processing in OpenFOAM 5 + jkeep OpenFOAM Post-Processing 0 June 17, 2019 02:07
Need help in post processing of Slurry flow in Ansys Fluent jatin1990 FLUENT 0 November 5, 2014 15:11
