How to model melting of a 3D STL object in flow-3d |
January 7, 2024, 07:42 |
hamed
Rep Power: 4 |
How should I enter the 3D STL file into the software so that the software recognizes it as a fluid?
Also, what are the best boundary conditions and physics of the problem for the simulation of melting? |
January 8, 2024, 00:30 |
Sehroosh
Rep Power: 7 |
You can import fluid region as STL in INITIAL window
January 8, 2024, 01:27 |
hamed
Rep Power: 4 |
January 8, 2024, 01:47 |
Sehroosh
Rep Power: 7 |
See the image
laser heat source, laser melting, melting, melting&solidification |
Modeling internal using porous media model - flow get stuck under the object | lucy. | Fluent Multiphase | 0 | July 13, 2023 04:43 |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 08:38 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
