Home > Forums > Software User Forums > FLOW-3D
FLOW3D POST: Query Scour depth/bed elevation at predefined points
Old   May 2, 2023, 14:39
Default FLOW3D POST: Query Scour depth/bed elevation at predefined points
Hiramani
hiramani12 is on a distinguished road
Hi folks,
I am using FLOW3D for sediment transport modeling. My model seems to running fine but I am having issues generating the types of visualizations I want. Specifically, I want to plot the scour depth or bed elevation at different points in my model over time. Can anyone provide me some ideas on how this might be done?
Also, as an overall issue, I have trouble accessing the types of data available in my model and exporting it for outside usage. For example, the net elevation change plot in POST shows the bed elevations for my whole model but when I try to export it, I am not sure what I can export so that only the surface of my bed is exported. Any and all help with this issue would be great. I am pretty new at this software and the learning how the software works is taking longer than learning the physics of the problem...
hiramani12 is offline   Reply With Quote
Old   October 11, 2023, 03:08
Sehroosh
MSM1985 is on a distinguished road
Hi. Hope you have find the solution. If not, try visualizing the simulation in flow 3D post. There is an result output of Packed Sediment Elevation Bed Change which will give you an idea of sediment deposition/scour on each time step anywhere in the domain.
MSM1985 is offline   Reply With Quote
Plot array over time in Flow3D Post abon FLOW-3D 0 March 1, 2023 05:12
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 16:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
